AZ v1.01 controller assembly for MPI
Last modified by Max on 2025/03/09 15:33
PCB
Let me remind you that when ordering a printed circuit board, you can use any mask color except red.
Necessary components
Resistors
SMD1206
47 Ohm - 7 pcs
330 Ohm - 1 pcs
1 kOhm - 21 pcs
4.7 kOhm - 7 pcs
10 kOhm - 10 pcs
Non-polar ceramic capacitors
SMD1206
10 ?F - 4 pcs [larger capacitance is acceptable]
SMD0805
12 pF - 2 pcs (C7 C27 - quartz strapping 32768)
22 pF - 2 pcs (C5 C6 - quartz strapping 24 MHz)
100 nF - 1 pcs
1 ?F - 31 pcs [larger capacitance is acceptable, except for C3 C18 C22 C26]
Microcircuits
SMT32F407VET6 - 1 pc [installation is acceptable SMT32F407VGT6]
KR531AP2 - 4pcs
KR559VN1-1pcs
KR155LA18 - 1pcs
LM1117-3.3V (AMS1117-3.3V) - 1pc
GAL18V8D-25LP - 2pcs
Installation
IDC 2x5 angular - 3pcs
MicroSD connector 9pin - 1pcs
Quartz resonator 24 MHz - 1pcs
Quartz resonator 32768 Hz - 1pcs
DIP8 switch 4 positions - 1pcs
Battery connector - 1pcs
Angular 6pin - 1pcs
DIP20 socket - 2pcs
Diodes
LED RGB 5mm with common cathode, diffuse - 1pc
BAT54C SOT23 dual schottky diode - 1 pc
Assembled boards
External appearance of assembled printed circuit boards
Assembly
Assembly order
It is recommended to adhere to the following assembly order
  1. SMT32F406VET6
  2. SMD components from the front side
  3. SMD components from the back side
  4. Installation products
  5. Microcircuits in DIP and other parts
  6. Jumper JP1 is soldered short-circuited
  7. GAL marking: U8 - one dot U9 - two dots
Preparing the controller for operation
  1. Flashing GALs and installing them on the printed circuit board.
  2. STM32 firmware
  3. Uploading images to the MicroSD card, installing the card into the controller
  4. Installing the controller into the basket.
  5. Putting it into operation
Partylist
Name      Value     Qty. Part                Description Footprint      Part Number
C1        1uf       31   CAP NP                          C_0805
C2                                                       C_0805
C3                                                       C_0805
C4                                                       C_0805
C13                                                      C_0805
C14                                                      C_0805
C15                                                      C_0805
C16                                                      C_0805
C17                                                      C_0805
C18                                                      C_0805
C19                                                      C_0805
C20                                                      C_0805
C21                                                      C_0805
C22                                                      C_0805
C23                                                      C_0805
C24                                                      C_0805
C25                                                      C_0805
C26                                                      C_0805
C28                                                      C_0805
C29                                                      C_0805
C30                                                      C_0805
C31                                                      C_0805
C32                                                      C_0805
C33                                                      C_0805
C34                                                      C_0805
C35                                                      C_0805
C36                                                      C_0805
C37                                                      C_0805
C38                                                      C_0805
C39                                                      C_0805
C40                                                      C_0805
C5        22pf      2    CAP NP                          C_0805
C6                                                       C_0805
C7        12pf      2    CAP NP                          C_0805
C27                                                      C_0805
C8        100nf     1    CAP NP                          C_0805
C9        10uf      4    CAPACITOR NON-POL               C_1206
C10                                                      C_1206
C11                                                      C_1206
C12                                                      C_1206
DN1       DIODE     1    DIODE_DUAL_CK_AAJ               SOT23
J1        NET10     1    NET10                           IDC-10MR
J3        MPI_half  1    MPI_half                        MPI_HALF_V2
J4        SD_Jack9  1    SD_Jack9                        MicroSD_9pin
J5        CON10     2    CON10                           IDC-10MR
J9                                                       IDC-10MR
J7        JUMPER4A  1    JUMPER4A                        SW4_DIP8
J8        UART      1    UART                            UART
J10       JUMPER    3    JUMPER2                         JUMPER 20/100
J11                                                      JUMPER 20/100
J12                                                      JUMPER 20/100
JP1                 1    jumper_2con                     PLS2
R1        1k        21   R                   Resistor    R_1206
R3                                                       R_1206
R4                                                       R_1206
R5                                                       R_1206
R6                                                       R_1206
R23                                                      R_1206
R24                                                      R_1206
R25                                                      R_1206
R26                                                      R_1206
R27                                                      R_1206
R28                                                      R_1206
R29                                                      R_1206
R30                                                      R_1206
R31                                                      R_1206
R32                                                      R_1206
R33                                                      R_1206
R34                                                      R_1206
R35                                                      R_1206
R36                                                      R_1206
R37                                                      R_1206
R38                                                      R_1206
R2        10k       10   R                   Resistor    R_1206
R8                                                       R_1206
R9                                                       R_1206
R10                                                      R_1206
R11                                                      R_1206
R12                                                      R_1206
R13                                                      R_1206
R14                                                      R_1206
R15                                                      R_1206
R16                                                      R_1206
R7        47        7    R                   Resistor    R_1206
R17                                                      R_1206
R18                                                      R_1206
R19                                                      R_1206
R20                                                      R_1206
R21                                                      R_1206
R22                                                      R_1206
R39       4.7k      7    R                   Resistor    R_1206
R40                                                      R_1206
R41                                                      R_1206
R42                                                      R_1206
R43                                                      R_1206
R44                                                      R_1206
R45                                                      R_1206
R46       330       1    R                   Resistor    R_1206
U1        531AP2    4    531AP2              КР531АП2    dip16
U2                                                       dip16
U3                                                       dip16
U4                                                       dip16
U5        75451     1    75451               К155ЛА18    DIP-8
U6                  1    LED_RGB_5MM_COMMON_CATODE       RGB_LED
U7        STM32     1    STM32F407VET6                   LQFP100
U8        G16SelV2  1    GAL18V8D-25LP                   DIP_20
U9        G16CtrlV2 1    GAL18V8D-25LP                   DIP_20
U10       SWD       1    SWD                             SWD
U11       LiBatt    1    LiBatt                          BAT2032
U12       LM11173.3 1    LM1117              LM1117      SOT223
U13       559VN1    1    559VN1              КР559ВН1    DIP_20
Y1        24MHz     1    Xtal                            CRYSTAL_HC49
Z1        32876     1    Quartz                          CRYSTAL_DT38
C2                                                       C_0805
C3                                                       C_0805
C4                                                       C_0805
C13                                                      C_0805
C14                                                      C_0805
C15                                                      C_0805
C16                                                      C_0805
C17                                                      C_0805
C18                                                      C_0805
C19                                                      C_0805
C20                                                      C_0805
C21                                                      C_0805
C22                                                      C_0805
C23                                                      C_0805
C24                                                      C_0805
C25                                                      C_0805
C26                                                      C_0805
C28                                                      C_0805
C29                                                      C_0805
C30                                                      C_0805
C31                                                      C_0805
C32                                                      C_0805
C33                                                      C_0805
C34                                                      C_0805
C35                                                      C_0805
C36                                                      C_0805
C37                                                      C_0805
C38                                                      C_0805
C39                                                      C_0805
C40                                                      C_0805
C6                                                       C_0805
C27                                                      C_0805
C10                                                      C_1206
C11                                                      C_1206
C12                                                      C_1206
J9                                                       IDC-10MR
J8        UART      1    UART                            UART
J11                                                      JUMPER 20/100
J12                                                      JUMPER 20/100
R3                                                       R_1206
R4                                                       R_1206
R5                                                       R_1206
R6                                                       R_1206
R23                                                      R_1206
R24                                                      R_1206
R25                                                      R_1206
R26                                                      R_1206
R27                                                      R_1206
R28                                                      R_1206
R29                                                      R_1206
R30                                                      R_1206
R31                                                      R_1206
R32                                                      R_1206
R33                                                      R_1206
R34                                                      R_1206
R35                                                      R_1206
R36                                                      R_1206
R37                                                      R_1206
R38                                                      R_1206
R8                                                       R_1206
R9                                                       R_1206
R10                                                      R_1206
R11                                                      R_1206
R12                                                      R_1206
R13                                                      R_1206
R14                                                      R_1206
R15                                                      R_1206
R16                                                      R_1206
R17                                                      R_1206
R18                                                      R_1206
R19                                                      R_1206
R20                                                      R_1206
R21                                                      R_1206
R22                                                      R_1206
R40                                                      R_1206
R41                                                      R_1206
R42                                                      R_1206
R43                                                      R_1206
R44                                                      R_1206
R45                                                      R_1206
U2                                                       dip16
U3                                                       dip16
U4                                                       dip16
U10       SWD       1    SWD                             SWD
Files
Gerbers for PCB
AZ_MPI_V1.01_MAXIOL_2020.RAR
